A reasonable price is some £50 for a warranted scrapyard engine. Period.
Add to this most of a workdays labour - and thats the top end.
206 - Son-in-law's woes
- x 8444
As Anders says, 1.1TU engines can be picked up very cheaply.
But hold on. This engine has a history of lost and missing sparks. How has the Indie reached his diagnosis? Fuel will flood the engine if there is no spark and it will dilute the oil and so on. He (the Indie) cannot condemm the engine until all the following checks have been made.
1. Is there a spark? If so, is it in time?
2. Is the mixture too rich and thus flooding the engine?
3. Is the cam in proper time?
4. Compression check on all 4 cylinders.
5. Check condition of Coolant Temperature and TDC sensors.
If the Coolant Temperature Sensor is duff (not uncommon as it's a bit fragile) it will cause the ECU to believe the engine is at about -50 degrees C and make the mixture very rich. If the TDC sensor is unhappy, it'll put the timing out and/or cause no or an intermittent spark. Going on the past history, the TDC sensor has to be a prime suspect.
I'll very much doubt the engine is duff at all. The TU engine I swapped the other week was wrecked because of a long-standing weak mixture due to an air leak which holed the pistons; this is very unusual. Generally the TU is a tough little number and as said before, it's a doddle to work on.
I'd get the car out of the Indie ASAP and get cracking on it. You have the skills to do a better job.
A 206 cannot be scrapped just because of this...
- x 8444
TDC Sensor would be my first look..superloopy1 wrote:Spoke too soon. misfire has returned moreorless immediately. Any ideas as first line of attack?
There is a Pug version of service.citroen.com. Look at the sticky at the top of this forum.
I've not tried it but I believe it is very similar...
- x 8444
The TDC sensor is down on the edge of the bellhousing at the front of the engine. It fits on a plate attached by a couple of small bolts. It ooks a bit like it's sandwiched between the engine and the gearbox.
It might be worth having the sensor out, giving it a clean and checking its connector.
The coolant temperature sensor is in the middle of the LH (as you look at the engine under the bonnet) side of the cylinder head. I think it's the one with the blue connector.
That is a serious amount of money for a diagnostics session
AndersDK
DaiRees
Hi,superloopy1 wrote:Finally, is there an equivalent to PR-NET (as was) for PEUGEOT cars? Can i get a breakdown of all parts to VIN number anywhere so that i can obtain the correct replacement parts,
I know CJ pointed you in the right direction but I wasn't sure if you'd found it.. Peugeot Servicebox is here http://public.servicebox.peugeot.com/ . It's excellent! You have to register but it's free
saabsalltheway!
hi a mate of mine has paid £300 for a 1.1 tu engine for a 206 a head off job would be about the same.
how can it be a problem with the engine it self cus it runs fine (sometimes) its got to be engine management ive had problems with indies b4 (see 406 hesitation) so get cracking on with the sensors
paul
paul
