I have a strange problem with my aircon, in that regardless of wheter it is switched on or not, its on!
The only way to stop it, is to either have the interior fan switched off, or disconnect the pressure switch.
It still runs, even with the on/off switch disconnected!
Anyone any ideas?
Jonathan
activa aircon wont switch off!
Clogzz
- x 40
Activamadness
XantiaMan
- x 18
The air-con should still be off if the switch on the dash is turned off and slider set to no fan, thats how mine works anyway. With the switch on but slider turned to off, the air-con is not activated but the moment its moved across or on auto, you can here it kick in and idle goes up.
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
2017 Fiesta ST
