Turbo pump for non turbo engine???
cityfinal
I have a Peugeot 306 1.9 diesel with a sick Bosch diesel pump. Can anyone tell me if I can swop it with a Bosch pump from a 1.9 td engine?
AndersDK
It might work well.
I'm unsure if the TD pump must be fiddled down to deliver less fuel for a N/A.
But that should not be too much a problem, only a question of wee slight turn on a max fuel setting screw.
There would of course be the pressure compensator from the TD intercooler to turn up the fuel on boost, but it should be fine simply blanking it off.
Anders (DK) - '90 BX16Image
XantiaMan
- x 18
It could work, the turbo has the compensator on the top of the pump but if it never recieves a signal then fuelling will never be increased at boost rate.
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
2017 Fiesta ST
