Renault Laguna TDi IP???
Richard C. Carrington
Unread post by Richard C. Carrington »
I am trying to find out it my V reg (2000) Renault Laguna Ibiza 1.9 TDi has a Lucas or a Bosch fuel/injector pump. My Haynes Manual is not very clear on this point, and I can't tell by looking at it.
May I assume it is direct injection and not indirect??? And is the fuel filter a heated one, it's got wires to it , but whether this wiring belongs to the ECU I don't know.
Also has anybody out there run one on Waste Vegetable Oil???
Any info gratefully received,
Cheers
Richard
Xaccers
x 186
Unread post by Xaccers »
I run my xantia on straight veg oil, if you're going to use waste, look into the refining/filtering processes, I wouldn't just pour waste veg in even if you just filter it.
DIY sphere tool
