Been directed from the retro rides forum as I have a ZX with a problem.
It is a 1900 diesel turbo estate and has handled badly from purhase a couple of months ago. Just been in and changed the front tyres and found the nearside bottom ball joint was worn so bought a new one and set about fitting it, turns out it is the hole in the strut that has worn and the cross bolt wont tighten up enough to take up the slack
Second question is, I have to change the CV boot, does the outer joint split? if so how? I yanked it today and the shaft came out of the gearbox instead.
I don't have a cone
With thanks
Alan
