Hi
On starting my car the front just drops and makes a creaking noise, is this normal?, has anyone experienced this problem?
I have tried raising the suspension and lowering it to get trapped air out, i think this is the right method!!!
Also can someone tell me what suspension components require regular greasing/lubrication. Can someone email me pics, i am a dummy when it comes to car part terminalogy.
Much appreciated
xantia 19td 1999 suspension creaks/drops on start up
- Donor 2023
- Lexia Available: Yes
- My Cars: 2008 C5 Exclusive Tourer
1993 Xantia 1.9 TD VSX Mk1 Sinker A.K.A Slugmobile 13'
'Old Katy'
previous convictions: totaling 52litres of LHM in one go:
1968 ID19B 'Old Polly' Stellar white
1993 Xantia 1.9 TD SX Mk1 Sinker Silver
1992 XM 2.0 SEi Turbo Manual Anthracite Grey
1982 CX 20 Pallas 'Old Goldy'
1993 XM 2.1 SD Auto Light blue
1993 Xantia 1.9 TD SX Mk1 Sinker light Blue
1982 BX 16 TRS 'Cyril' Vallelunga Red
1995 Xantia 1.9 D SX Auto Dark green
1977 CX 2400 Pallas C-Matic 'Aphrodite' Regatta Blue
1982 GSA Pallas SE Silver Pearl
1980 CX 2000 Reflex Vallelunga Red
1978 CX 2400 Pallas C-Matic 'Prometheus' Midnight blue
1984 BX 14E 'Cecil the slugmobile' Maroon
1987 Fiat Panda 'the mighty panda' - x 98
Hi, this is often caused by a bust accumulator sphere. It causes the anti sink valves to close as soon as the car is turned off (this should usually take longer) and the car doesn't get a chance for the suspension to lower down after you step out (when you get out the suspension goes a little higher and should automatically lower to readjust) it doesn't do it if the anti sink closes. It stays too high over night and next day start up, the pressure opens the anti sink valves and suddenly it lowers.
Anyway, if it's the accumulator then it is a green coloured sphere fitted to a valve block down low at the front behind the radiator - you'll see it from the top easy enough but it's reached from below, it has to have the 12mm bolt at the valve block loosened by 1/4 turn. The sphere is unscrewed after this - might well be tight and you'll need a chain wrench to remove it (or one of those special 'sphere tools' .
Lastly, it's a case of swapping the the O ring seal and screwing the new sphere from e.g. GSF in to hand tightness. Start up, tighten the 12mm bolt and job's done.
Not sure about the greasing - maybe the front struts and spray some grease on the height corrector mechanisms to stop 'em jamming.
Graeme M
