hi, i have just bought a citroen berlingo forte 1.9 diesel,
everything seems fine ,but when i went for a drive today the brake fluid level warning light on the dash came on every few hundred yards,and beeps i have checked the fluid level and toped it up but still get the same problem it is intermitent and the stop light on the dash does not light up with the other light,any ideas please
berlingo 1.9 brake warning light
reblack68
alan4heidi
thanks for reply richard, there does not seem to be a brake pad warning light,the book says that it is a warning lamp for hand brake and fluid level and indicates that the hand brake is applied or not released fully...also that the fluid level is insuffient...the lamp may also indicate a malfunction of the electronic braking distribution..... i have looked at the pad thickness today and they are about 4 to 5 mm,the book says 2mm minimum
- x 5573
- x 1044
- x 5573
