205 Oil Pressure
Post Reply
driversdomainuk
My Cars:
Contact:
205 Oil Pressure
Post by driversdomainuk »
Hi
I am getting low oil pressure warning under heavy braking. Have checked oil but appears ok. I use the car for competition use, and so is a slight concern.
The engine - a 200 bhp Mi16 engine on twin webers is almost new. Just wondering if there is something obvious. The car is a stripped out 205 gti
cheers
www.driversdomainuk.com
Drivers Domain UK.com
The UK Driver Training & Resource Site
AndersDK
My Cars:
Post by AndersDK »
Do you still use the original engine sump pan ?
If so this must be modified internally with carefully designed and precisely engineered baffles, to avoid the engine oil is pressed out into one corner of the sump pan during driving.
A standard sump pan is not designed for longish animated driving in curves. The oil pump will starve and run dry.
Do a search on the various maxspeed and racing websites on the issue - and you will get loads of info returned.
PS : extend your investigations in any possible issues with a wrong dipstick indication ... :shock:
Anders (DK) - '90 BX16Image
driversdomainuk
My Cars:
Contact:
I have a baffled sump and not the standard one but the problem is still there
Post Reply
