I have a problem with the Stop light and temp light illuminating intermittently when driving around town. All the fluid levels are fine, the temp gauge is working fine and the engine isn't overheating.
Does anyone know the operation of the temp circuit as to what might be causing my problems?
I've had a look at the blue connector located on the right hand side of the engine just below the air filter, when this is disconnected the temp and stop lights flash continuously. I've tried to clean up the connector as much as possible however the fault still remains. I think that it could be a sensor fault.
Any advice welcome
Regards
Howie
Stop light and temp light Xsara mk1
howiedean
Howie
2006 Fiat Idea Dynamic 1.3 Multijet
2010 Renault Laguna Dynamique tom tom 2.0 DCI 130
C5 VTR 2l 8v HDI Estate 112000 miles gone
Kia Rio 2007 1.5 CRDI 62,000 miles gone
2001 Dodge Durango 4.7 V8 170,000 miles gone
1999 Ford Crown Victoria 4.6 V8 151,000 miles gone
AndersDK
Hi Howie
The Xantia has got a different level sensor alarm circuit from earlier models (BX, CX ...) in that the sensor is located in the thermostat housing. This means an airlock could set off the alarm, as then the sensor pins gets dry.
Try bleed the cooling system using a homemade header tank.
Anders (DK) - '90 BX16Image
JohnD
- x 72
howiedean
Thanks for the quick reply guys. The HDI is the one giving problems, as soon as I get rid of one dash light another pops up.
The 1.4 touch wood seems a much better wired car even though it is the same year as the HDI.
I'm going to change the coolant so I'll bleed the system which will hopefully get rid of any airlocks. Incidently John can you remember how much it cost for a sender unit?
Cheers
Cheers
Howie
JohnD
- x 72
The sender was less than 10quid. I expected it to screw into the block but it doesn't. It just pushes into a hole with a rubber ring under it and the unit is held in place with a spring clip.howiedean wrote: Incidently John can you remember how much it cost for a sender unit?
Cheers
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
howiedean
Where is the sender that you changed located, as I've just replaced the one that fits into the engine (right hand side looking from the front of the car behined the air filter)? It screwed in however, which sounds to be different to the one you replaced.JohnD wrote:The sender was less than 10quid. I expected it to screw into the block but it doesn't. It just pushes into a hole with a rubber ring under it and the unit is held in place with a spring clip.howiedean wrote: Incidently John can you remember how much it cost for a sender unit?
Cheers
This item hasnt cured the fault, although it should be noted that once driving over say 35mph the light does not illuminate.
Help!!!
Regards
Howie
JohnD
- x 72
howiedean
Cheers John, just had a look at the diagrams.johninderbyshire wrote:http://www.frenchcarforum.co.uk/forum/v ... hp?t=23877
have a look at this, it may be of help.
John
I've just been having a look at my car:
1. The rad fans are not switching on when the coolant temp increases beyond
100 deg C (Aircon switched off and blower not switched to demist).
2. When demist/Aircon switched on the fans run to slow speed with the Left hand fan running intermittently (hence the stop/temp light).
3. At no time at all did the fan run at max speed even with the Temp in very high levels.
Any ideas?
I'm not sure of the circuit operation regarding the fans, as John's reference seems to display a single fan design with two resistor packs.
Regards
******* All sorted now, I unplugged all the connectors and relays in the circuit and reconnected them all. The the fans are working correctly*******
Howie
