For no apparent reason, whilst I was driving yesterday, the rear suspension went to the 'high' position. The front suspension responds correctly when the adjuster lever is set to either low/normal/high position.
In terms of ride comfort, the consequence of this malfunction is less of an issue when the car is driven on a open road (non-urban) with f3ew ruts and bumps. It will be a couple of days before I can get the car to a garage and I wondered if any damage would result from driving the car with the different suspension settings - i.e. on high at the rear and normal at the front?
Any advice?!?!
Cheers,
Mick
Xantia - rear suspension fault
alexx
