ZX brake balance sorted - day off well spent
N_CURTIS
Unread post by N_CURTIS »
Hi all,
Having got an advisory on the front brake balance for the ZX at the last MOT, I decided to tackle the problem today - day off - no rain!
The bottom sliding pin had siezed on the N/S, so I cleaned it all up and re-asembled with copper grease.
I decided to check the O/S and the bottom pin was partially siezed, so sorted that as above.
The bottom one suffers most in the line of duty, but I did notice a couple of small splits in the rubber boot on the N/S one though.
The pistons move freely both sides :D
Is it possible to buy these and the pins separately?
It's a Girling setup by the way.
Cheers
AndersDK
Unread post by AndersDK »
You can get service kits containing all rubber parts for one caliper.
They are commonly in the £6-£10 pricerange.
Pistons may be dealer parts only, and usually expensive (£50'ish)
Anders (DK) - '90 BX16Image
