Xantia Brake fade
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
Xantia Brake fade
hi all, had this yesterday.. a little suprised, as none of my previous xantias ever seemed to suffer..
Happened twice, after mildly spirited driving.. also got a nice brake smell
I will do a hydroflush in the near future..
Anyone else had this with LHM ?
thanks
John
thanks
John
Hi John,
The way you ask the question makes me think you're not expecting brake fade to be possible on a high pressure LHM based brake system such as the Xantia?
Vapor lock type fade from boiling the brake fluid cannot happen with the LHM system, no.
Even a bit of air in the brake lines will not cause brake fade - only a slight delay to operation.
On the other hand pad surfaces can fade like any other car with extreme heat. So either the pads are poor quality material, are not contacting over the whole surface of the pad (thus causing hot spots) which can be either pads or discs, or you are simply overheating the brakes.
Bear in mind that different models of Xantia's have different diameter and thickness discs at the front, and different size pads - and in my opinion the smallest size ones found on some models such as the 2.0i automatic are a little bit under rated for the job, the ones on the Activa/V6/2.1TD are significantly bigger and more robust, so maybe you are just expecting too much of them under hard driving.
Burning brake smell is definitely overheating of the pads...
Regards,
Simon
Regards,
Simon
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
What brand of pads do you have? On my Clio I found that the standard pads were great but tended to fade when pushed hard. I swapped them out with a set of ferrodo ds2500 pads and now I can beat on them much longer. If you enjoy the odd "spirited drive" then uprated pads might be a good investment
Also adjusting your driving style can give the brakes an easier time. Brake earlier and more progressively. This means that the suspension is more settled going into the corner and you can corner more quickly. Don't "punch" at the brakes as this causes the car to wobble. The added benefit is that the brakes won't fade as much.
'97 406 1.9TD, 314k.
- My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX - Contact:
The brakes on my Xantia are pretty pants at the moment but I think the last discs it had were cheapo ones (garage did it) and the pads are EBC. They're ok for town driving but if you want to stop a bit quick from high speed then as soon as they heat up it doesn't matter how hard you press you won't be stopping any quicker. I thought I might try some Black Diamond ones when they need changing, but not sure if it's worth the extra expense.
Lexia ponce
Lexia ponce
Onlinemyglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4920
Could it be that over the eight months you have been driving it in an "enthusiastic" fashion (and why not!) that the discs have worn down and are now less able to dissipate the heat, increasing the likelihood of brake fade?
If you are going to replace the pads, check the disc thickness. You might even be able to fit a heavier duty disc - but that might require different calipers of course.
Use the engine/gears to reduce your speed, rather than or as well as the brakes. Less chance of fade then.
Yes, they were c**p.
Lexia ponce
Lexia ponce
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1205
Brake fade used to be very common with drum brakes, the surface of the linings would take on a glass like appearance. In my younger days it was a constant problem, I must say though I have never had it with disc brakes, admittedly I dont drive anything like as fast now. I think that must have been a bit of very spirited driving!
Performance was no better than standard, they were noisy and the matching pads I had with them went down to the metal in 5000 miles and knackered the lot, sent them back and got a full refund.addo wrote:What happened - wear issues or poor performance?
Lexia ponce
Lexia ponce
Dont buy anything EBC. Brembo all the way.
2003 Ford Mondeo ST220
2002 Ford Fiesta Zetec S
2001 Ford Puma 1.7 VCT
2008 Ford Transit Mk7
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
