I am have the usual tick indicator relay problem.
I can see the relay and will replace.
But I believe from other postings that the indicator stalk could be the problem. I took off the bottom steering column cowl, and loosen the top bit but the indicator stalk seemed to be a closed unit.
Any tips on how to get it out and clean it???
indicator stalk replacement
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
hi 3ps
I did one a few years ago.. you have the clicking like mad relay I presume?
Getting the stalk out is easy, cowl top and bottem off (3 or 4 deep seated torx screws I think) although you've done this already..
the stalk is just screwed in as a 'block', unscrew and remove as a unit..
this can then be carefully dismantled by pushing in the plastic retainers all round the block..
access the contacts, clean, light oil or lube maybe, sorted
John
(there may be some springs so be careful and take your time)
John
