C5 hdi back end sinking
toldem_oldham
Hi all my c5 hdi has all of a sudden has decided to sink after car has stopped for more than 1 hr ,there is no sign of a leak plus when i click the remote to open the car i can hear the motors working for longer than normal so i know something is not right
02 c5 2.0 hdi sx estate
marsalek
- x 19
IMO it has nothing to do with height correctors or spheres. There is an antisink valve, that probably does not close (hangs). Maybe due to some dirt in LHS. Mine on Xantia behaved the same way two weeks in winter but all of the sudden, the problem disappeared by itself. The same happened to another colleague from a german xantia forum. If I were you, I would just wait a couple of weeks and if it doesn't cure by itself, you will probably need a new antisink valve. Those on C5s cannot be IMO serviced.
Karel
Karel
AndersDK
Re: C5 hdi back end sinking
Which motors ?toldem_oldham wrote:when i click the remote to open the car i can hear the motors working for longer than normal so i know something is not right
Anders (DK) - '90 BX16Image
- x 1044
AndersDK
Tx Wheeler -
Could not make any sense of buzzing or whirring motors - except exactly the BHI.
I have found that the dreaded rearsink on the earlier BX'es is really down to leaking rear suspension cylinders. Not the brake valve as suggested by many (including me myself
Since the later Xantia & C5 is of exactly the same construction, its likely to be the same problem.
Next question is why they develop this leak, as there is both a tephlone and rubber O-ring to seal off the cylinder piston.
mooseshaver
My rear suspension cylinders went at 6 years. Perhaps all the 02 ones are due to go?
I thought it was because we often carry a 19 stone disability scooter in the back.
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
toldem_oldham
mooseshaver
Mine never had any patches on oil on the ground when I parked. I jsut took it in for a service and MOT and was told they wouldn't let me drive it away again because it was leaking!toldem_oldham wrote:I was under the car today and could not see any visible leaks or even any wet patches sugesting a slight leak
Gone cars.
Gone cars.
AndersDK
Which is the most common reason to why owners find this problem a mystery !toldem_oldham wrote:I was under the car today and could not see any visible leaks or even any wet patches sugesting a slight leak
The leak is NOT external. No external drippping, weeping or seepage.
Not even a trace of it.
The leak is INTERNAL. Thats why you have the 2 hoses attached to the rubber bellow : the rearmost of these is the leakback hose returning the cylinder leak to the resevoir, while the frontmost is the vent hose to vent the bellow when it compress/extend during movements.
Note that the cylinders are DESIGNED to leak a small amount past their seals, to keep the piston and its seals lubricated. Its just that the piston seals takes this lubrication job a bit too serious over time ...
- x 5582
Which is probably the explanation for mine - there is a very slight weep on the rear offside, going in on Thursday for a bit of a checkover and a few minor odds and ends done, including that.
Guy anticipated that it would likely be the bellows weeping a bit as it has happened on a few he has fixed of about the same vintage.
bencowell
myglaren wrote:Which is probably the explanation for mine - there is a very slight weep on the rear offside, going in on Thursday for a bit of a checkover and a few minor odds and ends done, including that.
How many miles have you got?
Currently driving a 2004 C5 VTR (old shape) and an Electric Kia Soul. Sorry but the electric one is my favourite!
Formerly Hyundai Genesis 3.8 V6, 2 x Kia Optima, 2 x C5, Xsara and Saxo.
- x 5582
A little over 120,000.bencowell wrote:myglaren wrote:Which is probably the explanation for mine - there is a very slight weep on the rear offside, going in on Thursday for a bit of a checkover and a few minor odds and ends done, including that.
bencowell
Did you have the rear suspension replacement? I wonder if having mine taken apart at 12k miles will make it last longer!
Do you do Citraerobics?
den169
- x 5582
