As sure as night turns into day, it was not long before I was called in to cast a thought or two
The engine has what appeared the usual TU oil leak and signs of explosive coolant loss, but not much.. It still has coolant in it and it's clean.
The engine spins over with no compression at all. Cambelt I though but that is intact. The cam is rotating and valves are operating.
A compression test shows absolute zero on Cylinders 2, 3 and 4. I did not bother to test No.1. On how it sounds, No.1 is unlikely to have any compression either.
The owner, 17 years old, just got the car yesterday, just passed his test said all he heard was a rattle, a loss of power and then it died..
His dad is lifting the head this weekend.
Any thoughts on what has happened to loose compression totally on at least three cylinders? My only thought is destructive detonation and holed pistons or badly burned valves. The plugs are sparkly clean with no combustion products on them whatsoever. But why all four cylinders?
It's a TU1 engine.
