Xsara loosing power
shayneparker
Xsara loosing power
Unread post by shayneparker »
I have a Xsara 2.0 hdi (160k) on a T that keeps loosing power.
It goes allright for a while then the revs stop coming though. Getting up a hill is a challenge!
A mechanic had a quick look but I don't want to spend loads of money because it's a bit tatty and not worth a lot. He suggested it might be the front fuel pump (had the rear one replaced a while ago) I'd have thought that it would cut out alltogether though if it was a fuel pump problem.
Anyone had a similar problem with an HDi?
Cheers
Shayne
x 1044
Unread post by wheeler »
does the engine management light come on when it lacks power ?
shayneparker
Xsara loosing power
Well it's on most of the time. It came on about the same time.
Shayne
x 8119
Time for some diagnostics Shayne. See what fault codes are stored and have a look at what the engine is up to when running.
A stab in the dark suggests the mass aiflow meter. Before questioning any sensors though, have you checked that all pipework is sound and all electrical connectors around the engine are OK?
Whreabouts in the UK are you? If anywhere reasonably local to me, a free diagnostics session can be yours...
shayneparker
Xsara
Thanks Jim,
I'm in Newhaven however. I'll get it into my garage and find out what the fault codes are.
Shayne
