DMF's
JohnD
(Donor 2022)
x 72
DMF's
Unread post by JohnD »
I belong to two or three caravanning forums and there have been several reports of premature clutch failures on Pug 307 and 407 HDI's, but never on Citroens. Given that the C5's has the same engine and transmission, how come the problem seems to be confined to Pugs? Any ideas?
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
philipte
Unread post by philipte »
The problem isn't confined to Pugs by any means, the DMF on my C5 failed prematurely. First sign was brief clutch slippage when drving along, which gradually got worse and worse. Still, by driving carefully I managed over 80,000 miles before the slip became too bad to live with. The car was regularly used to tow up to a ton.
When I saw the old components the friction plate was virtually unworn, but the DMF had excessive movement between the two halves, and the flywheel face showed definite signs of overheating.
Rumour has it that the DMF can disintegrate and exit via the bellhousing. I'm sure it could, but with a degree of mechanical sympathy it is possible to nurse things along whilst preparing for open wallet surgery. :shock:
JohnD
(Donor 2022)
x 72
So maybe the DMF doesn't like towing. I believe Valeo have produced an alternative. It's a four piece kit which is much cheaper than a DMF replacement. The kit consists of a traditional rigid flywheel, a cover assembly, a high performance drive plate and release bearing. The vibration control function, originally performed by the Dual Mass Flywheel, is transferred to a long travel damper drive plate. In the event of needing a replacement, maybe this is the way to go.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
vince
x 13
Unread post by vince »
Being in the parts game, more and more people and garages are looking into the kits that convert back to solid flywheels as people simply cant see the reason why the design was ever changed and then being stumped with the higher cost on top....
Lets face it, how many flywheels have you ever had to change on all your old cars.......none? nope me neither.... :wink:
Gregg1100
x 5
DMF Dozy masochistic french (designers)
Unread post by Gregg1100 »
Hi Vince,
Same goes for PULL type clutches--what are they all about ?. Hit and miss whether you get the fork fingers in slots first time, and they get heavy action in a shortish period of time. The normal push clutch has been with us for years, easily aligned by a kit or an old first motion shaft
Like software on computers, newer is not usually better---too many bells and whistles/uneccessarily complicated.
Greg
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
Gregg1100
x 5
DMF
Sorry about double post--- :oops: :shock:
Greg
EDIT - Citrojim: No worries Greg, deletion is easy :wink:
x 1237
Unread post by Peter.N. »
The only failure you got with solid flywheels in the olden days was the starter gear ring wearing - before the days of pre engaged starters. :? :?
np
Unread post by np »
JohnD wrote:So maybe the DMF doesn't like towing.
I`ve just clocked 88k miles,32k since i`ve had it & re-mapped to 140 ish,the rest from new with my Dad.Both of us are caravaners.The car has towed to Italy 4 times & back,a few times to France,mega towing mileage from both of us.
Still have the original clutch & DMF.Although biting point is 3/4`s to the top of pedal now,but still going strong. :)
53`406 est SE Hdi 140,110k
AndersDK
Unread post by AndersDK »
Anyone with a clue on WHY the DMF clutctches develops the problems ?
AFAI see it its down to the bonding being too soft, and then the clutch initially bounce because of the load and sets off slippage. Once started it wont stop until load removed, and will of course set off again on next load occurrence.
The whole thing gradually tend to set off on less & less loads because of the bad/damaged bondings which gradually allows for too much movement between the components.
Any other explanations ?
Anders (DK) - '90 BX16Image
bencowell
Unread post by bencowell »
My C5 HDI 110 had a powerbox fitted at about 25,000 miles. Clutch started slipping at 55k, replaced at 60k to be on the safe side.
The old friction material was like new and you could move the two halfs of the flywheel with your hand.
Clutch replaced with a Valeo solid flywheel replacement. Much much better.
The biting point is now constant (now got 95k on the clock), the clutch lighter and more progressive. It is easier to drive smoothly.
I'd recommend the Valeo solid replacement to everyone with the slightest hint of clutch problems.
Ben
Currently driving a 2004 C5 VTR (old shape) and an Electric Kia Soul. Sorry but the electric one is my favourite!
Formerly Hyundai Genesis 3.8 V6, 2 x Kia Optima, 2 x C5, Xsara and Saxo.
reblack68
Unread post by reblack68 »
Our C5 has only done 60k and the clutch should last the life of the car. It annoys me greatly that not only am I going to have to replace the clutch but it's going to cost me several hundred pounds instead of the £100 it should cost.
It's not giving trouble yet but it will. I'm still convinced it's responsible for turning the C5 into a slug.
Richard
Care of a 1994 205 D.
ACTIVE8
x 6
Unread post by ACTIVE8 »
D.M.F...............I.E... Dual Mass Flywheel.
Seems it really should be......Develops More Faults. :wink:
ACTIVA
