406 power steering
np
406 power steering
Unread post by np »
My b in laws 406 2.1td,R reg i think,has sprung a leak.From what he says,theres a pipe coming off the power steering pump,metal,then crimped into a rubber pipe,about 2ft long.Its leaking at the crimped joint.
The question is,once he(or me :lol: )have replaced the pipe,does the system need bleeding :?:
never had to change one before,but i assume its just a case of changing said pipe,topping up fluid,the turning steering from lock to lock a few times then check level :?:
53`406 est SE Hdi 140,110k
x 8048
Nope, no bleeding par-se. Just refill with fluid and with the front wheels off the ground and engine running, move the steering from lock to lock a few times and all air will be expelled. Top up, job done :D
The process is not unlike the "Citarobics" us Citroen types do on our hydraulics to bleed air.
reblack68
Unread post by reblack68 »
That's how I've done it when I've changed steering racks.
Richard
Care of a 1994 205 D.
reblack68
Too slow :D
Richard
x 8048
reblack68 wrote:Too slow :D
Fingers on buzzers...
Look at the post times Richard :lol: Bang-on exactly the same time!
Now what are the chances of that?
np
Unread post by np »
Not fixed yet as he can only get the pipe from Peugeot & its £100.
