hi guys
does anyone know if its possible to buy a kit to make up lengths of lhm pipe (i assume that a normal brake pipe kit wouldnt be adequate)
Cheers
making lhm pipe
weety
making lhm pipe
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
- x 5571
andmcit
- x 30
GSF do sell the special joints/seals and pipe, and I believe you can still
buy the 3.5mm flaring tool as a bench/vice mounted die or a smaller hand
held one from Pleiades.
http://www.pleiades.uk.com/products_3.html
I believe that there is only the type A tool (3.5mm and 4.5mm) @ £56+VAT
That said, it appears there aren't any available at the moment but
they're in production but may be a while!
With some of the duff pipes I've seen on some Xantiae recently,
I'd recommend you get yourself sorted with one of these when they're
available again asap!!
N65972 BRAKE PIPE-50M ROLL ROLL OF 3.5MM HYD PIPE FOR CITROENS 50M 65.00.
N65996 PIPE SEAL LHM TYPE 3.5MM PIPE SEAL BX;XM;XANTIA;CX;GSA LHM 0.60
N65988 PIPE NUT-3.5mm NUT FOR N65972 PIPE BX;CX;XM;XANTIA 0.40
Andrew
Andrew
- x 5571
Couldn't say. Not often I need to see him (once a year on average)superloopy1 wrote:Which 'indie' do you use? Has he an all round knowledge including V6?myglaren wrote:Presumably, as the independant Citroen specialist I use can make up pipes onsite.
He is George Fraser in Sunderland.
If you want to pursue it go with caution, there are two. They are brothers, too, which adds to the confusion.
You can PM me for further details - don't want to spam the site without approval.
