VSS on 306 (Vehicle speed sensor)
rayc
Unread post by rayc »
I have just bought a 306 1,9 td (P reg) for a friend. I need to sort the a/c out as it's not working.
The concerning part for me is that I have found the vss wrapped around a water pipe and not plugged into the gearbox.
Couple of questions.
1) can anyone tell me where this locates as I cant find the access point.
2) what is the function of the vss as the speedo is working fine! :?
Cheers all
Ray
x 1060
Unread post by wheeler »
are you sure its not the engine speed sensor rather than the vehicle speed sensor ? the speedo would not work if it was the vss.
Does your car have a rev counter ? does it work ?
rayc
The rev counter works. I assume it's a vss as the cable is thick black with approx 1.5" snsor on the end . It looks as though it could be the vss but as the speedo etc work I wasn't sure of it's function. Timing maybe?
x 1060
Can you post a pic of the plug/sensor ?
what colour is the plug & how many pins does it have ?
