Im in the market to purchase a Xsara Picasso 2.0HDi.
Due to budget I was looking for one around 2000 - 2002.
Can you give me any advice on what too look for when purchasing one of these cars.
Ive read that they have issues with clutchs, suspension and a FAP filter.
Any further information or correction of the above will be greatly appreciated.
ps: I applogise if a similar question has been posted before and I did search through the archive before postingbut could not find what I wanted.
Thanks and regards.
Paul.
2000 - 2003 Xsara Picasso 2.0HDi Checklist
willinot
nick
I would be suspicious of any HDi that didn't start and run perfectly, both hot & cold. If the engine takes loads of cranking to start this can indicate possible fuel system problems which can be expensive to fix.
Check all the electrics work properly, if not this can be caused by problems with the BSI on multiplexed Citroens which again can be expensive.
There are rumours of clutch problems on HDis, but this seems to be entirely down to the dual mass flywheel fitted on some.
No 2.0 HDi Xsara or Picasso was fitted with a DMF, so this won't be a problem on the ones you're looking at. (Some of the more recent 1.6 HDi versions do have them)
Again, no 2 litre Xsaras/Picassos had FAP filters, only the 1.6 sometimes did.
willinot
willinot
reblack68
C.J.
Been reading and hearing a great deal about DMF's failing recently. What actually causes this expensive failure, and what can be done to reduce the risk, or is it inevitable on all modern diesels....presumably doesn't apply to petrol driven cars?
Colin
My cars:
1988 AX GT and still running sweet. Genuine 41 k only!!
2005 Skoda Fabia vRS 83k...and truly awesome.
Vauxhall Combo crew cab SE
Citroen Saxo 1.4 Furio.
Their cars:
Hyundai Getz.
Hyundai i20
Eriba Puck caravan now too!!
My cars:
Their cars:
Hyundai Getz.
Hyundai i20
DickieG
- Monaco's youngest playboy
- x 38
I believe the failure occurs due to the bond between the rubber and metal sections of the flywheel not holding. This happened to my Mum's Gold TDi @ 3,000 milesC.J. wrote:Been reading and hearing a great deal about DMF's failing recently. What actually causes this expensive failure, and what can be done to reduce the risk, or is it inevitable on all modern diesels....presumably doesn't apply to petrol driven cars?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
reblack68
The way to reduce the risk is to take it off, throw it away and fit a proper flywheel. I know a conversion kit is available for the HDi.
The failure occurs because it is a stupid idea. Somebody has sat down and given a lot of thought to how they can introduce a new way for a car to break down expensively. Just when they develop the technology to extract massive amounts of torque from a diesel engine they develop a flywheel that can't handle it?
I strongly suspect the DMF of making our C5 lethargic when it has the same engine as the much livelier Xantia.
Richard
Care of a 1994 205 D.
C.J.
So what difference would you notice.....not that I've got an HDi YET.reblack68 wrote:The way to reduce the risk is to take it off, throw it away and fit a proper flywheel. I know a conversion kit is available for the HDi.
What's the point of a DMF anyway? Something to do with reducing vibration is it?
Colin
My cars:
Their cars:
Hyundai Getz.
Hyundai i20
My cars:
Their cars:
Hyundai Getz.
Hyundai i20
mooseshaver
Its to reduce noise. And apparently money in your wallet.C.J. wrote: What's the point of a DMF anyway? Something to do with reducing vibration is it?
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
mooseshaver
This might help http://youtube.com/watch?v=YnaXB8q3uzQ
It shows what a Dual Mass Flyweel looks like.
Gone cars.
Gone cars.
C.J.
Couldn't get any sound/explanation to go with that link Moose', otherwise quite a helpful clip, thanks.mooseshaver wrote:This might help http://youtube.com/watch?v=YnaXB8q3uzQ
Sorry Paul. I/we seem to have hijacked your Picasso thread here.
All relevamt though I suppose.
I had one of the very first 2.0 HDi Picasso's to be registered up here on merseyside, back in June 2000, and it proved to be a very satisfying and reliable car over 3 years and 40k.
It has it's design faults, as I told Citroen HQ. The worst one being the appauling dash reflection onto the screen, since sorted with a darker dash now I believe. All in all a great car though, and my mate who works for a Citroen main agent, reckons it's still a better all round car than the new C4 Picasso with all its fancy electronic gadetry.
Colin
My cars:
Their cars:
Hyundai Getz.
Hyundai i20
My cars:
Their cars:
Hyundai Getz.
Hyundai i20
willinot
steelcityuk
Some info about dual mass flywheels on Lucas site - http://www.luk.com/content.luk.de/en/pr ... zms_sv.jsp
I'm under the impression that on some vehicles it's recommended to replace the flywheel when doing the clutch so the bill for parts can be over 1K - Audi maybe?
Anyhow back to the original question, Car Mechanics magazine did an article in the April 2008 on diesel diagnostics. If you can get hold of a copy it was a good article.
Steve.
Steve.
not applicable
nick
I don't know if that relates specifically to the Picasso, but the HDi isn't particularly known for cooling problems. Direct injection diesels pass less heat into the cooling system than indirect injection so the cooling doesn't need to be quite so heavy duty.willinot wrote: What about overheating and radiator problems. Again its something Ive came across on internet searches so just want to make sure Im looking in the right areas over and above the standard things to look for.
Head gasket failures aren't unheard of on the HDi, but aren't all that common. The 2.2 seems to suffer more than the 2.0.
