sony mp3 player
jon8152
sony mp3 player
Unread post by jon8152 »
i all have got a sony cdx s2200 mp3 player in my 2000 xantia hdi and noticed it has a socket for remote will this work with the steering wheel controls with the correct lead Connects2 CTSONYLEAD thanks jon
reblack68
Unread post by reblack68 »
I think you'll need a proper conversion cable, which seems to cost about £40.
There are varying degrees of success in using these things but I believe Sony head units generally work quite well.
Most car audio retailers should be able to sort you out but, as ever, shop around.
Richard
Care of a 1994 205 D.
Ross_K
x 110
Unread post by Ross_K »
Autoleads PC99-109 cable will work fine also.
steelcityuk
Unread post by steelcityuk »
Unless you have to have steering wheel controls the proper Sony 'joystick' would probably be cheaper and control more functions. I had one in my Xantia, I fitted it where the cruise stalk would normally go.
Steve.
not applicable
den169
Unread post by den169 »
I had a sony mp40 in my xantia it worked fine with the steering wheel controls .And now it works with the stalk control in my c5.
