looking for part number - xantia TD 99
wonderd
Unread post by wonderd »
Since we don't have citroen-pr.net anymore, can anyone help me with finding the part number for the (green?) plastic part that holds the window and connects to the electric window regulator?
Or, instead, i can use the drawing of the electric regulator and the way it connects to the window.
Thank you.
Elad.
Xantia 2.0L 16V manual trans. 96
Xantia 1.9L TD 99
MikeT
x 232
Unread post by MikeT »
wonderd
no english?
Xantia 1.9L TD 99
MikeT
x 232
Ah, yes, good point. As I'm already registered I could change the language preference to English but it looks like you have to register in French first. :?
If I knew where to look I'd get the info you need - otherwise perhaps someone French speaking could help you register or use an online translator?
wonderd
I would appriciate the help - in the first post i wrote what i need.
I need the JPG of the electric regulator for the driver's side (left hand) - or the part that connects betwin that and the window itself.
Thanks.
Xantia 1.9L TD 99
x 8050
It's not too hard to work it out..
Press the S'Inscrire button to start the registration process,
Choose Particulier on the next screen and press the Valider button.
Then fill in the name and address fields and enter your chosen password in the Mot de Passe and Confirmation du Mot de Passe boxes.
It will then send an email to the addresse email du compte you entered and confirmed to advise you of your login details.
The email they send often gets trapped by anti-spam filters so if it does not arrive shortly after you register, look in any junk e-mail folders...
You can change to English then as soon as you log on.
x 1432
Here's the pic:
I suspect you want part 6 or 7?
Which are:
6: 0000922720 CLIP 0.59 GBP 0.69 GBP
7: 0000922721 BEARING 0.73 GBP 0.86 GBP
It is worth persevering with service.citroen - it's OK once you get past the French!
wonderd
Thank you, that's exactly what i was looking for.
Is that the specs of a 99 model (I think MK2?) because i have a 96 model and it looks a lot like this one, but it does not match the 99 model.
Elad.
Xantia 1.9L TD 99
wonderd
What the h** is that? :
Création impossible : un compte existe déjà pour cette adresse email
Xantia 1.9L TD 99
wonderd
Managed to sign up and in...Thanks.
Elad.
Xantia 1.9L TD 99
