I want to remove the roof bars but don't know what I'll find as they appear to have been there a while and held in place by wonky self-tappers.
Would I regret removing them? i.e Say I find or create unsightly marks and then be unable to refit the bars again due to bodged fasteners?
Roof Bars - leave or remove?
jeremy
Are these factory fitted bars on an estate - running the length of the roof? - like I have on my BX estate?
Quite correctly we are being advised to remove roof racks and rails - which go straight across the roof - and impede the airflow quite considerably. However the rails will only cause a marginal increase in drag as their frontal area (which is the bit that really matters) is quite small.
I wouldn't dare take them off the BX - they may stiffen the structure!
jeremy
AndersDK
Xaccers
- x 185
My old Mk1 95 saloon had rubber covered holes at the top of the doorway front and back.
Had to slice them open to fit the roof bars.
Looked like a nylon or other hard plastic threaded socket that they went into, so no chance of leaks etc without the bars.
They used to make an aweful racket if I left them on, and reduce my fuel economy.
DIY sphere tool
DIY sphere tool
MikeT
- x 232
Yes, they are bars that go across the width of the roof and are fastened through the door seals which I assume is the standard method of fitting. It's the fact they're held in place with what looks like a variety of different sized (even different alloys) self-tapping screws that makes me hesitant about removing them initially, especially as some are obviously inserted off-angle. I'm going to leave them on until I've used the rest of the tank of diesel then I'll probably remove them. Ideally, they'll come off and the paintwork can be cleaned up with the bonus that I can refit if needed. What I don't want to find is permanent roof marks.
xac: Hello again, good to see you back on this forum, hope all's well in your world.
Xaccers
- x 185
Good to be back
Does it have rubber roof pads as well?
I'm going back 8 years or so (and I'm getting old so my grey cells aren't what they used to be).
Those pads may have left marks from any dirt that's accumulated around them.
Any marks around the actual fixture points should be covered by the doors so isn't too much of a biggie.
You should see the mess veg has made of Cassy around her fuel cap!
DIY sphere tool
DIY sphere tool
MikeT
- x 232
jgra1
- (Donor 2021)
- x 36
Hi Mike, from memory, 4 x M8 bolts should go through bar brackets into roof.. allen/hex bolts ideally
not self tapping.. into hardended threads as Xac mentioned...
On this subject, I want to fit my bars for the summer, quite often in the past I take the bars off but leave the four brackets bolted in, Is this likely to make much difference to economy? saves some hassle
John
John
