Xantia Mk1 tickover
MikeT
x 232
Unread post by MikeT »
The bosch fuel pump is, by default, set to operate at a raised idle. There were several designs to control this, apparently, the waxstat being one of them. However, I am only familiar with the electrovalve type which utilises a vacuum to pull on a cable, negating the increased idle when the engine is warm.
Locate the fast idle lever at the rear of the fuel pump, cambelt end. With the engine running - taking all sensible precautions - try to push the lever using a screwdriver or similar against the return spring force and you should notice the revs drop. If so, then your controlling device has failed.
x 8063
The waxstat was the earlier arrangement fitted to non-EGR and fully mechanical pump versions of the engine. '95 models could have either the waxstat or electrovalve depending on the pump fitted. If you have the semi-electronic pump and ECU, you'll more than likely have the electrovalve system.
The waxtat itself is a large alloy cylinder that screws into the thermostat housing with a bowden cable existing from it going to the pump fast-idle lever. It works on the same principle as a themostat where the wax expands with heat and this movement is transmitted through a bowden cable.
After a few years they stop working and in fact, very few work at all these days. They are cheap enough to obtain but are a pain to replace because you need to drain the coolant and access is not particularly wonderful. Many, including me on my old TD, live with duff waxstats :roll:
The electrovale system is under ECU control and is dependant on the coolant temperature as read by the green sensor on the thermostat housing and a functioning vacuum pump, to be found on the end of the engine, driven by the camshaft.
