Xsara estate rear hatch locked
Nutcase
Unread post by Nutcase »
Got a problem with the rear hatch stuck in the locked position!
I suspect it may be a broken wire in the loom where it enters the door, but unfortunately that is inaccessible with the door closed! (had a similar problem with a wire to the rear wiper some time ago).
Also, you can only remove the interior door panel with the door open as most of the fixings are inaccessible although I have managed to pull enough of it clear that I can reach into the door cavity where the lock motor is. Great I thought, should be able to feel a bit of linkage and pull it to release the lock. However, the device seems to be a sealed unit with no uncovered parts, sitting directly over the lock mechanism (or maybe its a single integrated assembly?) :roll: I can feel the feed cable but can't feel/see what sort of connector it has or how to release it, and not much room to try and break into the cable to try a bypass.
Anyone got any tips on how to try and get the door open without damaging something in the process?
The car is a 2001 (MkII) 2.0HDI
All thoughts welcomed
Cheers, Greg
2001 Xsara HDI 110 150,000 & counting!
x 1044
Unread post by wheeler »
Do you mean the tailgate (bootlid) door or one of the rear side doors :?:
Nutcase
Sorry, I meant the tailgate!
As it happens I have managed to sort it :)
After much groping around trying to disconnect the plug to the lock motor (unsuccessfully!) I tried opening the door with the handle and it worked.
Then removed both the lock and the door handle switch (what a pain) and there was a goodly amount of corrosion in the connectors to both - cleaned these up and everything back to normal. Glad it wasn't a broken wire in the end as that would have been much more of a hassle to repair!
The Haynes bol bore no resemblance to the locking mechanism on my car (which is the MkII) - the latch and central locking motor are an integral unit, and the latch (once it is unlocked with the keyfob) is released electrically by a switch in the door handle - no mechanical linkages at all.
Regards,
Greg
x 1044
there is a manual release on the mk2. if you look on the latch on the side facing into the boot there is a small hole you can put a thin blade screwdriver in & trip the lock.
uncle buck
x 10
Unread post by uncle buck »
I think the electric hatch release on the Xsara II was a poor idea, when it was frosty we could never get ours to open, it clicked as you pressed the button but not a full click just sort of half a click & as there's no key over ride you are stuck!....as soon as the car warmed up a bit it started to work again…this went on every frosty morning :roll:
wheeler wrote:there is a manual release on the mk2. if you look on the latch on the side facing into the boot there is a small hole you can put a thin blade screwdriver in & trip the lock.
That’s a handy tip…I’ll have a look for it tomorrow :wink:
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
nick
Unread post by nick »
uncle buck wrote:I think the electric hatch release on the Xsara II was a poor idea
I agree, the first time I saw one of these was on a mklll Mondeo and thought at the time what a pointless complication it was. I had no idea Xsaras used them until I bought one!
I suppose its partly a security feature, unlike a conventional button with a keyhole its not possible to ram a screwdriver in and force the lock to turn.
x 1044
I believe all citroen (cars) since the mk2 Xsara have the same manual release.
