Window washers C5 2.2 Hdi estate
spudling
Unread post by spudling »
does anyone have any experience of C5 window washers. Got a 2.2 hdi estate basically the washers work when they want now they appear to have given up the ghost!! :x
Any info would be great as i really dont fancy a trip to the garage!! :evil:
bencowell
Unread post by bencowell »
The estate washer pumps are sensitive to the screenwash used. I think people advise putting a hosepipe down the filler tube and giving it a good blast.
Have you checked the fuses? Can you hear the pump working?
If you top up the screenwash does it leak out of the tank?
Currently driving a 2004 C5 VTR (old shape) and an Electric Kia Soul. Sorry but the electric one is my favourite!
Formerly Hyundai Genesis 3.8 V6, 2 x Kia Optima, 2 x C5, Xsara and Saxo.
birstall
Unread post by birstall »
If the problem is on the front jets: I had the same problem and I used a portable compressor to clear them. First I disconnected the pipe at the joint on the underside of the bonnet and blew compressed air through each of the two sides. Then I blew air through the actual jets themselves using the small airbed attachment for the compressor. It took a couple of tries at this. They seem fine now and have been working OK for some months.
Current: C5 HDI Exclusive Saloon
Past : C5 HPI Exclusive Saloon
C5 HPI Exclusive Est
Xantia 1.9TD VSX
BX 1.7 TZD
spudling
Thanks for the advice, I'm not getting any sound from the pumps is this an easy problem to rectify. Thanks 8-[
bencowell
Is the fuse ok?
spudling
yep checked all fuses, all seem ok.
birstall
Yes. I wasn't getting any sound from the pumps either. Maybe they stall.
:D
Xantia 1.9TD VSX
BX 1.7 TZD
