i have a 1999 xsara west coast 1.4i which has the following problem.
when engine is at working temperature it revs whilst at a standstill and when you try to accelerate does not pick-up immediately or sometimes stalls very easily, if it does stall, it is very hard to re-start and there is a strong smell of petrol.
I have been told that the problem is most likely to be the MAP sensor.
Is this correct? and if so where is it located and how do you replace it.
thanks mark
xsara west coast 1.4i possible map sensor fault
- x 8082
Hi Mark and a big welcome to the forum
The MAP sensor might be the problem although they are normally fairly reliable. More likely is an inlet manifold air leak anywhere between the engine and throttle butterfly causing the MAP sensor to receive false information.
A very common cause of an air leak is the pipe that connects the MAP sensor to the inlet manifold. These often perish. Look for a small bore pipe leaving the inlet manifold and going to a small box with an electrical connector on it. I'm not at all familiar with the Xsara unfortunately. In other TU engined cars I've seen, it is up on the bulkhead or the RH inner wing. If you listen carefully you may be able to hear the air leak hissiing.
Hopefully, soon, a fellow Xsara owner will tell you where the MAP sensor is on your car.
markmay
xsara west coast map sensor
Thanks Jim,
Have just had a good look/listen to the engine bay, but can't locate the pipe. I can however hear air hissing, but am unsure where it is coming from. It is most prominent around the area of the belts so i am not certain if its them that's making the noise.
uncle buck
- x 10
Hi Mark,
I think this is the MAP sensor on our Xsara 1.4.
I'm new to all these fancy control devices on petrol cars (more of a Diesel man) so I have no idea of what the symptoms of a dodgy MAP sensor would be...I'm sure someone on the forum will though.
If the engine is reving due to an air leak a good way to find this is to spray WD40 onto any joints you suspect....if the reving drops check the joint.
The engine in our Xsara does tend to sound like it's hissing a bit when its running so don't confuse this with an air leak.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
markmay
uncle buck
- x 10
As you are not sure that this is your problem could you not try a breakers yard for the part...the 1.4 engine was fitted to a lot of Peugeot & Citroen vehicles & the MAP sensor you need was probably fitted to other makes also.
Get the numbers / code from your part & I'm sure you will find the part you need.
I also tend to find that whenever I visit a breakers yard when I get home there is always a few other spares that have managed to find their way into my pocket somehow !
markmay
xsara 1.4i MAP sensor
Thanks Uncle Buck,
Yeah, sounds like a good idea, i think I'll go with the minimum amount of cash in my pocket, coz I know what you mean (alloys,spoilers)
Mark
Mark
MikeT
- x 232
Replacing parts on speculation can be an expensive business and if money is an issue, I wouldn't advise you take that route.
If you have a multimeter, it should be possible to test the output is not only within range (which is all the ECU can test for) but also giving correct readings according to vacuum.
Have a read here for an idea...
http://autorepair.about.com/cs/troubles ... 03a_06.htm
- x 8082
uncle buck
- x 10
Re: xsara 1.4i MAP sensor
Go with Mike's suggestion first.
No No No...the bits in my my pocket were free !markmay wrote:Thanks Uncle Buck,
Mark
markmay
- x 5580
