New spheres, no leaks, car goas back up quickly when i put on weight.
When standing with engine on, i can press the back all the way down fairly easily.
BX too soft on bumps
wonderd
Xantia 2.0L 16V manual trans. 96
Xantia 1.9L TD 99
Xantia 1.9L TD 99
- x 1238
wonderd
- x 1238
Mandrake
- x 694
Re: BX too soft on bumps
What makes you think there is a problem ?wonderd wrote:New spheres, no leaks, car goas back up quickly when i put on weight.
Unless its a BX 16v or 19GTI which have stiffer than usual suspension, theres nothing unusual about being able to press the rear suspension right down by hand on a hydraulic Cit - I can easily do so on my VSX Xantia, and could with my trusty old GS from years ago too.
Is there something wrong with the ride or handling ?
A little more background maybe ? How long have you had the car and is this the first time you've put a new set of spheres on it ? Have you had or driven other similar model BX'es before to have some frame of reference ?
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
wonderd
Yes it goas all the way down to the bump stops and that's the problem.
Actually it's not my car but a friend's.
It's not the first time i change spheres, i had 2 bxs before and never had that problem. I don't think it should go all the way down to the bump stops then i press the back with my hands or when i go over road bumps.
At the first couple months since i changed the spheres there was no problem, then i had a leak from one of the return lines and the problem started. After i fixed that leak the problem stopped for a month and now returned.
I will ask my friend but i don't think there is any stiffness from the steering wheel.
Elad.
Elad.
Xantia 1.9L TD 99
Xantia 1.9L TD 99
- x 94
