Any hints on installing reversing sensors in a C5 hatch?
Since the car features can bus/multiplexing, can I simply connect the sensor unit to the reversing light wiring (somewhere in the c-pillar)? Any precautions to take?
GB
C5 aftermarket reversing sensor installation
GB
05 C5 VTR 2.0 HDI
115k
115k
DickieG
- Monaco's youngest playboy
- x 38
Re: C5 aftermarket reversing sensor installation
To stand any chance of success with your idea you'd need to use the original Citroën reversing sensors and wiring loom, then get the car connected up to a Lexia or Proxia to tell the BSI that reversing sensors have been fitted. That may work but it would partly depend on whether reversing sensors were an option on your particular model and whether the BSI is able to recognise the sensors. The fact that reversing sensors were available on other models does not mean that the BSI on your car will be able to recognise them.GB wrote:Any hints on installing reversing sensors in a C5 hatch?
For instance on my Berlingo 1.6 HDi the BSI had been programmed by Citroën not to recognise cruise control whereas on my previous 2.0 HDi it had.
For the definative answer ask a Citroën dealer although they may be reluctant to enable your proposed change to the BSI as Citorën UK have clamped down on such modifications recently.
However, if you want to give it a go I know of two people who own a Lexia and one of them isn't very far from you
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
GB
Genuine Citroen reversing kit = £383 plus fitting and configuration (including four rear sensors). No way. Deep pockets and short hands here...DickieG wrote:To stand any chance of success with your idea you'd need to use the original Citroën reversing sensors and wiring loom, then get the car connected up to a Lexia or Proxia to tell the BSI that reversing sensors have been fitted.
Any chance of getting away with an aftermarket kit and a single by-pass relay instead? Anyone successfully installed an aftermarket reversing kit using the rear bumper cavities (factory) on a C5 II?
Ideally I'd like to install the four sensor Valeo Beep&Park kit (~ £50).
I had a look at Citroen spare parts website, and they list two different reversing kits compatible across the Citroen car range - they appear to be of the aftermarket sort (Delphi and Meta System), so my guess is that they are compatible with the C5 II canbus system.
BTW, the Meta System (incl. 4 sensors) is £138 (part number 0000945295), but according to the installation guide it is necessary to drill holes in the rear bumper - my car already has sensor cavities in the lower part of the bumper, so I don't want to do any unnecessary drilling.
http://www.citroen-docom.com/cs/notices/1467.pdf
The Delphi kit costs £178, but there are no downladable instructions available. No Citroen dealer seems to know anything about either of these kits.
Surprisingly they are both suitable for the new C5 III.
Cheers,
GB
05 C5 VTR 2.0 HDI
115k
115k
- x 5586
Have a gander in here.
There have been some fitted sucessfully recently and I believe the Valeo kit is the one Citroen use.
Unfortunately the search function is currently borked so I can't home in any closer, even worse, although there are four forums for different purposes there ay as well not be as folks chuck anything anywhere, regardless of forum headings. It is a mess compared to this place.
- x 1044
