XUD9 rocker breather
tomsheppard
The pipe has become brittle (as in detached). A new one was a very reasonable £3.50 but the bottom of the pipe is a long way down at the back of the oil filler. How do I remove the stainless hose clip on the end of the fractured pipe without having to remove the thermostat housing etc. Surely there has to be a way. I am sure that it was originally tightened in situ but I fear that it has a ratchet like a Ty Rap to stop it from coming undone. Can the oil filler be safely prised out instead? Seeking advice here seems to be a safer alternative to simply applying brute force!
Dave Burns
- x 3
Iv'e got a couple of 19td's on the garage floor at the moment Tom and have had a look at them with regard to your dilemma, I think you are in for a hell of a struggle to get the old pipe off and a new one back on with the filler in situ, my advice would be to remove the starter motor so you can get at the clip securing the filler at its base so it can be removed.
There is also another short pipe from the filler to the block under the stat housing that would need to have its clip trashed, just stick it all back together with jubilee's.
Dave
Dave
tomsheppard
vanny
this may or may not be a dump question, but where did you buy the pipe? I need one, although i really need a new engine.
Dont suppose you have a spare do you Dave?
Vanny
Merseyside, UK
Citroenbx19rd@bxproject.co.uk
http://www.bxproject.co.uk
Vanny
Merseyside, UK
tomsheppard
