Hi guys, just a quickie,
can I use veggie oil in my xantia mkII hdi 90?
some people say yes, some say no!!!
I have used it for many years in my old 1.9td, but this is a diferent set up. Bosch injector and stuff...
Paul
xanita HDI 90 and Veggi oil
1xAmi,3xGS,2xBx,2xAX,2xSaxo,1xXantia mk I,2xXantia MkII,1xC1,2xC2,
Most likely is that the incorrect viscosity of the fuel meant that either the tank lift pump or the high pressure pump couldn't build up enough pressure to trigger the pressure sensor.
You can't rely on this always being the case though - HDi engines can and will run on incorrect fuel long enough for them to do themselves damage.
They don't have a fuel quality sensor as such, just sensors for fuel temperature and pressure.
