Ok, so the glow plugs were done two weeks ago, at first starting was better but this week its rubbish again.
If I haven't got enough problem on my hands taking a day off to replace the radiator then the heater matrix also having a hole in steaming up my windows, im also getting laughed at when i first start the car up due to all the smoke!
Whats next, fuel filter? The unit that drives the glowplugs? Scrap yard?
Cant start:Glow plugs
Cant stop: Brake pads, Brake discs
Overheating: Radiator leak
Cant see: Heating matrix leak
STOP!: LHM leak
Cant show my face: Loads of smoke - unresolved!
Next! Xantia plugs done, still cra*p starting -LEMON
RugbyPete
- x 1238
elma
- x 287
Re: Next! Xantia plugs done, still cra*p starting -LEMON
Xud 9 cooling systems are under such high pressure you wouldn't get a steamy window you'd get a soaking carpet.
That is unless you need a water pump as well
- x 5582
Could it be rain coming in through the heater air intake below the windscreen?
Perhaps the drain is clogged and trapped water being evaporated and condensing on the screen.
If it isn't accompanied by a distinctive smell I'd check to see how the system is drained.
I had a similar thing on the GS and there were a couple of rubber 'teats' in the wheel arch. Squeezing them released a load of leaves and dust, along with a minor waterfall.
uncle buck
- x 10
If when you renewed the glow plugs the car was starting better & now 2 weeks its back to bad starting I would check the glow plugs are working.
The TD need long burn plugs for the post heating cycle it has (normal diesels don't have this) ...its not uncommon for normal plugs to be supplied instead of the long burn plugs the result is that they only last a week or so.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
- x 1431
