Steam coming out of air vents
RugbyPete
Unread post by RugbyPete »
this mornign i couldnt de-mist the windows.
It was so cold, i put the heaters on and blew then to the floorpan... well, the car just filled full of steam! all the way to work.
Im worried either pressure has built up int he system and blown something on the heater matrix or something else.
One thing i did do is splash then engine with water as i needed to take the air out of the system, opened the bleed valve and coolant came out, so simply washed it off. Im hoping some water got in somewhere and its not a leak...
ideas?
chest hurt when i got in, breathing in coolant steam!
Penguin
Unread post by Penguin »
My ZX used to do this. Don't know what caused it, but it used to stop after about 10 minutes. Never got to the bottom of it as I killed the car earlier in the year (much to my wife's delight!).
Sorry, this hasn't helped you much has it.
x 5577
See the several other related posts - your heater matrix has developed a pinhole. You should be able to demist on cold but it will be slow and uncomfortable.
Try some leakfix of some description (Barrs Leaks) but eventually you will need to replace the heater matrix.
oscarloco
Unread post by oscarloco »
Heater matrix. I had the same problem twice, fixed with Barr's Stop Leak. But as someone said before, the only complete cure is to replace it.
Oscar Lopez
'94 ZX 2.0 8v petrol (restoration to its former glory on its way after being neglected by stupid Ex)
x 8072
Barrs will certainly do the job for a while. It is in my 2.1TD. I still get an occasional whiff from it but water consumption is nil.
I have a new problem with the Activa though. When the blower is running very fast, I get fine white dust coming out of the vents :? No idea what it is. I've put a new pollen filter in and it is still happening. Methinks the matrix is corroding externally and it's aluminium dust coming out...
MikeT
x 232
Unread post by MikeT »
citrojim wrote:I get fine white dust coming out of the vents :? No idea what it is. I've put a new pollen filter in and it is still happening. Methinks the matrix is corroding externally and it's aluminium dust coming out...
Oh, please no :shock: My latest xantia had a lot of dust around the dash and when I ran the blower full speed yesterday, a mini dust storm of fine white particles blew out of the vents.
oscarloco
This could be caused by mineral buildup around the leak in the heater matrix.
Oscar Lopez
x 8072
oscarloco wrote: This could be caused by mineral buildup around the leak in the heater matrix.
Thanks Oscar, I think you've got it spot on :D
MikeT
x 232
I was hoping there'd been some sort of atmospheric fallout in the Bedfordshire area :lol:
