Hi all, I was driving down the motorway last night at a reasonable speed when I felt a power loss as I came off the slip road I could clearly hear the turbo whistling (I cant normally hear it at all) now its got very low acceleration and Its hard to get up to 70mph and it smokes on full throttle.
I'm guessing the turbos gone or could it just be a pipe come adrift.
Any one give me an idea where to start looking.
Tim
Power loss Have i blown the turbo ?
XantiaMan
- x 18
If the turbo had gone, it would smoke like a train all the time. Far more likely is a boost pipe popping off or spliting.
Gareth
Gareth
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
2017 Fiesta ST
XantiaMan
- x 18
Just to add the smoke you see flat out will be overfuelling because the air doesnt match the fuel. You make no mention of the car but this doesnt really matter, any turbocharged car thats had a pipe come off does the same.
2017 Fiesta ST
2017 Fiesta ST
deian
tdolman
- x 8063
That is good Timtdolman wrote:Thanks all you werre right the pipe from the turbo to the intercooler had come adrift (phew)
Tell you what, you should hear and see one pop off when you have your head under the bonnet. It goes offf with a really loud "POP"
Normally, this happens when I forget to tighten up a jubilee clip
tdolman
- x 5571
Mine "Popped" off one morning while taking my son to work and it really did pop, together with the throttle pedal kicking back followed by a loud prolonged hiss.
There were no other indications of anything wrong so I just carried on and dropped him. All seemed normal until I hit the upgrade on the way back.
Normally ascend it at around 70. Wouldn't do more than 40.
Naturally I started to worry then, imagining the big bills. Just pushed the tube back on when I got home and investigated, never any more trouble.
It did highlight that the turbo DID actually work for its living after all.
This was the Xantia, not the C5
- x 1430
First time it happened to me was just after I changed the cam belt - my first one. Had that dread feeling I had wrecked the engine - much better when I realised it was just a loose hose
Second time was giving it plenty on one of the uphill dual carriageway sections on the A66 - felt something just as we crested and I lifted off, then on the next section, foot on the boards in 3rd and nothing. Fortunately the only tool I had in the car was a screwdriver 8) Damn hot reaching under the top hose on a hot engine though....
