Relay ID reference
MikeT
- x 232
Relay ID reference
I've identified a Cartier relay 02009 as the fuel pump relay? Haynes lists the fuel pump relay as item 1200 though I can't see it anywhere on their diagrams. It has terminals numbered 1-5 with 1 & 2 being 12V +ve & -ve while 3, 4 and 5 are unlabelled. Can anyone enlighten me as to what I do have and what the pinouts are? Thank you.
Clogzz
- x 40
Quick look at BoL 1996 … nothing either.
Hope the relay is of the garden variety, like the cooling fan changeover relay.
1 & 2 are the coil … pins 85 & 86.
3 is the input … pin 30.
4 is output when the relay is at rest … pin 87 a.
5 is output when the relay is energised … pin 87.
AndersDK
