LMH FLUID, xantia
randomx
LMH FLUID, xantia
Unread post by randomx »
Hello all, need some info
HOW MUCH FLUID DOES IT TAKE TO FILL THE RESERVOIR TO THE REQUIRED LEVEL ON A XANTIA.
HOW IS THE LEVEL CHECKED, IT SAYS THAT THE LEVEL IS CORRECT WHEN THE FLOAT IS BETWEEN THE RED LINES WHEN THE SUSPENSION IS IN THE MIN POSITION.
Regards Mike.
michael
shaunthesheep
Unread post by shaunthesheep »
mine takes 5.4Ltrs, xantia, 1.6L, '93.
park on a flat surface, then you should move the height level to the max, then check the lhm level.
the red/orange disc should be between the two rings when car has settled to the max height.
dom
AV
Unread post by AV »
My float doesn't seem to move, wherever the suspension is set , is this a problem?
alan s
RIP 2010
x 6
Unread post by alan s »
I've always used a very scientific method of checking LHM level;
when the fingernail of your forefinger is in the fluid at normal driving position height, then it's about spot on.
I'm serious, I've used that method for years and it hasn't let me down yet.
Mind you, I'm always careful when using knives otherwise I'll have to find a new system. <img src=icon_smile_big.gif border=0 align=middle> <img src=icon_smile_big.gif border=0 align=middle> <img src=icon_smile_big.gif border=0 align=middle>
Alan S
alexx
Unread post by alexx »
A little more about science: in my BX, LHM level is about 9.5 cm below the filler neck, in normal driving position.
alan s
RIP 2010
x 6
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>
<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
Yup,
That's about the length of my finger alright. <img src=icon_smile_big.gif border=0 align=middle> <img src=icon_smile_tongue.gif border=0 align=middle>
Alan S <img src=icon_smile_clown.gif border=0 align=middle>
Zummerman
Unread post by Zummerman »
Wow Alan, You've got long fingers!<img src=icon_smile_wink.gif border=0 align=middle>
shaunthesheep
alan,
shall we all call you MR ALAN SISSOIRHANDS <img src=icon_smile_tongue.gif border=0 align=middle> form now on
dom
tomsheppard
Unread post by tomsheppard »
Surely this only works on the Activa? As far as I knew the others don't have digital control?
allmond
Unread post by allmond »
Oh very good! Sat there looking at it for a while, then it clicked!!
Jamie
