Hi all
there is a td xantia on ebay with a sick auto box, has anyone done a manual conversion on one of these?
i assume the bolt pattern is identical, but what about the hole in the firewall for the clutch cable? can a clutch pedal be mounted into an auto car easily or does the mounting bracket need changing - is this a dash out job? (eww) are the driveshafts the same? what about gearbox to shift lever linkages, can they be swapped without dash removal?
bye all
Auto to manual conversion - Xantia TD
- x 94
juraj
- x 94
juraj
- x 8072
- x 94
yes it can, but what i was trying to say is how much harder it is to work on a XANT to a BX, i was refering to the pedel box change HE HE HEjuraj wrote:malcolm
well the car sold and i didnt win it! didnt bid at all actually, but engine out job? surely a xantia box xan be removed without the enginecoming out?
bye
regards malcolm
- x 8072
