Hi all.
Following on from my woodshed story I have a question.
How do you go about removing the relay box from the NS inner wing?
Cheers
ZX Question
James.UK
I think you have to remove the battery and its tray. I seem to recall there were some fixings under there..
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
jeremy
N_CURTIS
Thanks for the replies.
Mine too has a shelf/board in it and having had another good look, I can see a nut on a stud that holds the base of the box to the inner wing. A similar setup to that which holds the PAS reservoir.
The box does feel quite well fixed, so I'm guessing there is more to it that than just that one nut. I'll try and remove the shelf/board (hopefully without breaking anything!) and go from there.
Thanks again.
Thanks again.
