Hi
I drove my car 10 miles to the next town and realised that the heater was on cold so slid the lever over to Hot and put blower on. The car filled with either smoke of steam not sure which.
I pulled over and checked under bonnet rad n water level fine oil fine no apparent leaks when I turned lever back to cold it stopped and has not done it again since this morning.
Any ideas please guys
Smoke or Steam in Xantia 1.9td
soupy_sam
Sam de Lessups from Coventry West Midlands England
Xantia 1.9 TD 1995 185000 this old girl went to sleep.
Picasso Exclusive 1.6 HDi 2005 29500
JohnD
- x 72
rabenson
Was there any smell? if not then it probably wasn't any form of smoke. Keep a close eye on your water level in case you have a slight leak in the heater matrix. If neither of these then, as johnd says above, probably some form of condensation. If your water level stays ok and it doesn't do it again, I wouldn't worry about it!
Cheers
Ron
Cheers
Ron
2007 C6 2,7 HDI exclusive 95k
2004 C5 VTR HDI 103k
soupy_sam
mezuk04
- x 1431
