forgive my ignorance, I have a 1996 406 1.9td, does it have a fuel pump or is the fuel sucked up via the injector.
I only ask because I am tempted to use biodiesel or veggie oil - I understand that all 1.9td's have bosch injector pumps which are apparently more favourable to bio/veggie fuel.
All advise appreciated.
Many thanks.
406 1.9td fuel pump and injector
- x 8444
Hi and welcome to the forum
The Bosch injection pump on the 1.9TD 406 is in effect two pumps in one; it has a lift pump to draw fuel up from the tank and a high pressure pump to inject metered fuel, via the injectors, into the engine.
Running on veg is possible with the Bosch pump and a search in the Citroen area of this forum will give you all you need to know. The contemporary Citroen 1.9TDs use exactly the same engine as your 406.
Note that only the Bosch pump is suitable. Please ensure positively that yours does indeed have a Bosch pump. The alternative Lucas pump fitted to some Peugeot 1.9TDs is definitely not veg-friendly and it will soon throw its toys out of its pram in a very destructive and expensive manner on even comparatively small ratios of veg oil.
sdw76
greg123
Plumb bob
bigjl2
You can get SVO from costco for £0.842 a litre, but you have to be a member.
Xantia 2.0SX estate (now sold)
Xantia 1.9 TD SX hatch 102K (all old MOT'S) and working A/C.(Sold to forum member, time to save for a C5)
2007 Berlingo Multispace 1.4i Forte, bought in November with genuine 27k miles, now on 39799 miles.
