Hello
Have removed gearbox from Synergie, 2.0 HDi. (Year 2000).
I can find no identification marks on it, where the marks should be. Have been told that this is an ML5T gearbox, but have also been told that this is wrong, (by a local car dismantlers).
Is there a difference between the ML5T and an ML5, see http://www.peugeotlogic.com/workshop/ws ... code1d.htm
More confusing, this site says it is an ME5K, http://peugeot.mainspot.net/eng_uk.shtml
Any help would be appreciated.
Thank You
help identify gearbox
- x 8078
a 2.0HDi can be fitted with either a BE3 if it's the 90bhp variant or the ML5T if it's the 110bhp model. This may be what is condfusing your breaker..
For easy identification, the BE3 has a rod operated gearchange whereas the ML5 has a cable operated gearchange.
Pop up a picture if you can, for a positive ID. Also, if you post the exact engine designator or VIN number, pr.net will identify positively the gearbox.
MikeT
- x 232
toofargone
MikeT
- x 232
Is this your car?
Product type CAR
Commercial marque/Component type CITROEN
Vehicle family EVASION - SYNERGIE
Silhouette FAMILY SALOON
Trim level HIGH HIGH
Engine DW10ATED TURBO DIESEL
Transmission BVM5
Model Year AM 2000
Interior trim type "FM" ANCONE VELOUR
Upholstery colour "FT"
Gearbox (Characteristics) BVM ML5T
Engine (Type) EW/DW
Other badge 2 0 HDI
Other badge, " Misc. " NO ADDITIONAL BADGE
Badge SX
Then this is your Gearbox/Driveshafts...
Transmission BVM5
Final drive ratio REAR AXLE HYPOID GEARSET 15 X 67
Speedometer drive TACHO TORQUE 25X20
Wheel style OPTIMIZED WHEEL
Tyre (Size, Type) 205X65X15 H TYRES
Wheels fitted 6,5" RIM ROAD WHEELS
Wheel (Type) STEEL WHEELS
Gearbox Type GEARBOX ML
Product type CAR
Transmission BVM5
Model Year AM 2000
Engine (Type) EW/DW
Other badge 2 0 HDI
Badge SX
Transmission BVM5
- x 8078
toofargone
The gearbox had two problems.
The main problem was that it would often, (90% of time), not go into second. If you used a very strong jolt then it might engage. Otherwise it just slipped out again. I tried to engage second gear at the gearbox itself yet it still would not stay in gear. The times that it did engage second gear worked perfectly--and once engaged it did not slip out.
The lesser problem was that in reverse things did not sound very healthy.
Thanks again. The forum is very very helpful.
