Warning light after LHM fluid change.
randomx
Unread post by randomx »
Hello,
Looking for some hehp, had some cleaner in the hydraulic system over the last two weeks. Change back today with new fluid. Everything seems to have gone ok. Suspension feels fine, brakes are fine, steering is fine. One thing though, the red 'STOP'earning light has been on since alone with another warning light. When I plug out the level sensor on the reservoir the light goes off. The only thing I can think about is that I may have put too much fluid in the reservoir ! Im wondering if this makes sense and if its potentially harmfull .
Regards Mike.
michael
x 1453
Could be that you haven't put enough fluid in, or the sensor has got stuck - try giving it a tap and see if ti comes up.
Richard
