wierd vibration at 60 mph
admiral51
x 389
Unread post by admiral51 »
Hi all
have just done a mini service on the good ladys xantia 1.9d 1996 and have taken it for a spin tio check everything is ok
everything fine until you get to about 60-65mph then there is a bad vibration felt through the steering wheel and feels if car wants to pull to the right.
i have checked tyre pressures and they are ok but i get no feedback under braking and all other times car drives in a straight line
could it be balancing (i know had bad she drives :lol: :lol: ) or tracking
all ideas welcome
colin
AndersDK
Unread post by AndersDK »
Swap wheels front<->rear and check what happens then.
Most easy way to to pin down a defective wheel.
Anders (DK) - '90 BX16Image
x 1238
Unread post by Peter.N. »
10-1 it will be a wheel balance problem but it could be caused by a defective tyre. Doing as Anders says will help you track it down.
wrinklet1
Unread post by wrinklet1 »
Have you checked that the wheel nuts are ok and that there isnt a wheel pin that the wheel goes on? similar to the rear wheels?
Paul
1xAmi,3xGS,2xBx,2xAX,2xSaxo,1xXantia mk I,2xXantia MkII,1xC1,2xC2,
