Back to the fold
wrinklet1
Back to the fold
Unread post by wrinklet1 »
Hi all,
I'm back already.
I have got a Xantia MkII HDISX hatchback. not sure if its a 90 or 110
93,000 on the clock fairly good nick for £1150
Paul
1xAmi,3xGS,2xBx,2xAX,2xSaxo,1xXantia mk I,2xXantia MkII,1xC1,2xC2,
Mandrake
x 694
Unread post by Mandrake »
You bought it, but you're not sure what it is ? Wow you must be keen. :lol:
Welcome back anyway... :lol:
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 1431
To check for 110:
1. The gear lever is sort of wonky! It leans over to the passenger side of the car when in neutral.
2. Open bonnet and have a look at the air pipes - 110's have a second air pipe running alongside the air box.
110s go like stink on the open road.... :lol:
wrinklet1
Hi, it looks like a HDI 90, not the 110
Runs smooth enough but it doesnt seem the get that surge when the turbo comes in like it does on the 1.9 td.
I have to replace the rear spheres, not a hard job though.......
Paul
x 8071
RichardW wrote:The gear lever is sort of wonky! It leans over to the passenger side of the car when in neutral.
Ahh, and there was me thinking only my Activa did that :D Must be a quirk of the MK2 cable change. My MK1 2.1 with the same gearbox but a different cable set-up does not do it, the gearstick is perfectly centred :?
Another easy way to tell if it's a 90 Paul is by the gearbox. 90s have the BE3 with rod linkage change whereas the 110 has the cable-change ML5.
Sadly, it seems only the 1.9TD has that "coming on boost" feeling :(
wrinklet1
Hi, it's a 90bhp model. Seems slow though compared to my old 1.9td :?
Sounds quieter though
x 8071
wrinklet1 wrote:Hi, it's a 90bhp model. Seems slow though compared to my old 1.9td :?
Don't be fooled Paul, it's just a deceptive feeling, the same is said of the 2.1TD as well. The deception is continued by the quietness of it :D
lolingram
RIP 2010
Unread post by lolingram »
As the song (nearly) goes 'it's just an illusion'.... on the other hand the fuel consumption is something else.
Don't be fooled Paul, it's just a deceptive feeling, the same is said of the 2.1TD as well. The deception is continued by the quietness of it ..
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
