Xsara central locking
seritiku
Unread post by seritiku »
My xsara a 1999 1.9 diesel non turbo will not lock the tailgate along with the four doors via the remote keyfob...I looked in the handbook and it said to put the key in the tailgate and withdraw it at 45 degrees but this has had no effect...Has anyone on here had a similar problem and if they have had how is it cured..
P.S I can hear the tailgate mechanism moving when I use the keyfob but the tailgate doesn't unlock using the keyfob I have to do that manually..
All advice appreciated..
Regards Seri
Ma voiture est français..citroen xsara picasso 2003 2.0 Hdi MPV
Ma autre voiture est...skoda fabia 1.4 MPI
Ma moto est...yamaha xj600
MikeT
x 232
Re: Xsara central locking
Unread post by MikeT »
I think, at least with my xanita, that you remove the key when in the horizontal position or the vertical position, depending on which does which. That would make it 90degrees between.
EDIT: Sorry, you're quite right, clockwise from vertical 45 degrees it is! However, that is to set it to key locking. You want to withdraw it when vertical for it to unlock with the doors.
x 1044
Unread post by wheeler »
sounds like the end of the lock soleniod that connects to the lock mechanism has popped off, you will probably hear it rattling about in the tailgate. just pop it back on but re fit it with super glue to stop it coming off again.
seritiku
Thanks fellas I will try both of your suggestions... :wink:
