Has anyone tried this homemade fault code reader?
oscarloco
Unread post by oscarloco »
Hi guys
Browsing thru the web I got to this page.
http://www.tramontana.co.hu/citroen/fuel/test.php
It is a BX site and has lots of info for testing and diagnosing the BX. Among the goodies in this page, there is this homemade fault code reader:
Has anyone used it? Is it safe? Can it be used to diagnose the Magneti Marelli 8P ECU found on the ZX?
Thanks!
Oscar Lopez
'94 ZX 2.0 8v petrol (restoration to its former glory on its way after being neglected by stupid Ex)
x 8089
Oscar,
you have a PM :wink:
EDIT: the above *may* work with the Magnetti-Marelli 8P but definitely will not work with any Bosch ECU. They can only be "read" using pukka diagnostic tools as they communicate with a serial data stream similar to OBD but too different to be read using the standard OBDII code readers :(
oscarloco
citrojim wrote:Oscar,
PM responded! :)
Thanks Jim. One more question,is it possible to damage the ECU trying the homemade code reader? I might give it a shot but only if there is no chance of frying the ECU. If I fry it, show is over for my ZX as it's almost impossible to get the parts down here :(
Oscar Lopez
MikeT
x 232
Unread post by MikeT »
I've just made something similar for my Ford and it works very well. The danger is in the test load you use. An LED draws very little current compared to a bulb for instance, and drawing too much current will fry the output driver in the ECU, rendering it useless for diagnostics. Obviously you want to take all standard electric/electronic precautions mentioned, make sure you observe polarities etc.
I was always led to believe the Citroen ECU's were an entirely different kettle of fish but if it's just a matter of jumpering a connector and counting pulses then I think I can do that :lol:
