Xanita Sump -2 drainplugs?
paulbx
Unread post by paulbx »
Xantia estate hdi 90
Folks
Did the usual oil and filer change this weekend (every 5,000) and for first time noticed TWO drainplugs on sump - one in the usual place and another about 3 cms above.
What's this for?
PaulB
Broomie(paulB) Xantia Hdi 90 estate
x 8063
I believe it's for an oil temperature sensor Paul. Some high-spec Xantias had an oil temperature gauge.
paulbx
thanks!
cheers mystery over - its blanked off
np
Unread post by np »
My high spec VSX TD `97 had the oil temp gauge fitted in the dash clocks,but it still had 2 sump plugs fitted,one about 3 cms above the other. :? :)
53`406 est SE Hdi 140,110k
MikeT
x 232
Unread post by MikeT »
I would have thought 3cms up the sump is not an ideal place for a temperature sensor. Could it be an overfill drainage hole?
XantiaMan
x 18
Unread post by XantiaMan »
Maybe its just a 'generic' sump to suit different applications?
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
