Have just returned to French cars by purchasing my third Xantia this time an HDI Exclusive Estate. It has a few little problems as expected..
The door trim that is clipped in to the outside door keeps un clipping itself. The trim pushes back in fine but quickly pops out again. This happens with both front doors. Any ideas please?
Next problem a rear wheel arch has accident damage. Is it reasonably simple to change the wing or would I be better asking a repair shop to quote for repairing and spraying the existing panel?
Next on the list is........ Fix two electric windows, replace sphers, flush out lhm system, apply forte radiator additive, remove towbar, get radio code.....
Already done, replaced indicator stalk, cleaned out lots of dirt, serviced...
Xantia Exclusive Door Trim/Rear Arch
mattpc
Xantia number three is..
HDI Exclusive Estate Cat C
elma
- x 287
Re: Xantia Exclusive Door Trim/Rear Arch
Probably a little white clip.mattpc wrote: The door trim that is clipped in to the outside door keeps un clipping itself. The trim pushes back in fine but quickly pops out again. This happens with both front doors. Any ideas please?
Grab from the scrapyard or I've seen them for sale in motorworld.
