c5 hdi hydralic pump
toldem_oldham
Unread post by toldem_oldham »
As there is no haynes manual yet for the c5 is there a procedure for taking the pump off,it is rattling badly but no problems with the suspension or steering yet but dont wanna risk break down and is it true its £1200+ vat for a new one or am i gettin flanneled a breakers yard wanted £300 with no warranty for 1 from a y plate bit pricey these pumps aint they :shock:
02 c5 2.0 hdi sx estate
AndersDK
Unread post by AndersDK »
The pump is included in the hydrailic valve block which certainly is "a bit pricy".
Have you fault traced your C5 to a positively defective hydraulic block ?
Even a few quid spend on a Citroen garage for a correct diagnosis may come out as big savings on the final.
Anders (DK) - '90 BX16Image
x 1044
Unread post by wheeler »
A BHI unit is around £700 new. If you get one from a breakers make sure its the same spec i.e. sport button, Xenon headlights, variable power steering (only on the V6). if the spec is different it will have to be reprogramed by Citroen or someone with a Lexia/Proxia.
rowanmoor
Unread post by rowanmoor »
Just out of interest, what difference does the presence of xenon lights make to the programming of the BHI unit? The other options you mention make perfect sense, but I cannot make the connection so assume there is something about the C5 I don't know about (not having one and all).
Cheers,
Rowan.
x 1044
all cars fitted with xenon headlights (from the factory) must have headlamp washers & automatic beam height correction by law. on the C5 it uses the same body height sensors for the auto headlamp adjustment as it does for suspension adjustment, by programming it this tells the BHI that it needs to pass the body height info onto the headlamp ECU's
AndersDK
Which is exactly the reason why you can not retrofit Xenon lights - except if all the Xenon bells & whistles are fitted too.
rowanmoor
I wondered if it was that.
Given that the car is already self levelling, won't the sensors always tell the lights to be in the same position no matter what? Surely about the only fault there can be for the suspension to get the level wrong is a faulty sensor so it would still set the lights to the same position even though it is wrong because it thinks it is right due to a dodgy sensor. Which would make all that complex stuff completely pointless. I guess that is legislation for you.
How do other cars do the light levelling? Do they also use sensors on the rollbars just for the lights?
Cheers,
Rowan.
x 1044
rowanmoor wrote: How do other cars do the light levelling? Do they also use sensors on the rollbars just for the lights?
Well the C4 & the C8 do.
AndersDK
Some cars use a built in electronic horizontal level sensor.
toldem_oldham
Just had a citroen mechanic look at my hydraulic pump he says its not that and poss bottom pulley thats rattling he says common on c5 so its off to him for a closer look after easter :)
